How to Programmatically Display / Hide Multiple Plots in the Waveform Chart
Updated May 22, 2019
Multiple plots are displayed on the waveform chart. Can I display or hide individual waveforms programmatically?
Several methods are conceivable, but the following attached file is an example. You can select a waveform using the property node of the waveform chart.
