Archived:LabVIEW 2018 Crashes After Windows Build 1809 Update
Updated Apr 5, 2022
On the 22nd of January 2019, I installed Windows Build 1809 Update on my PC. Since this update I have had numerous LabVIEW crashes.
LabVIEW has crashed under the following circumstances.
  1. Recompile -> Run Application -> No Issues -> Close Project -> Reopen Project -> Run Application -> LabVIEW Crash
  2. Run Application -> No Issues -> Close Project -> git push -> other computer -> git pull -> Open Project -> Run Application -> LabVIEW Crash
Make sure that the Windows Build .NET 1809 Update is installed in addition to the main Windows Build 1809 Update.
January 22, 2019 — KB4481031 Cumulative update for .NET Framework 3.5 and 4.7.2 for Windows 10, version 1809 and Windows Server 2019
If the issue sill persists. Please contact NI Support
From Microsoft:
"For 24 hours, this Jan 22, 2019 Cumulative Update for .NET Framework 3.5 and 4.7.2 (KB4481031) was made available broadly on Windows Update as an automatic update. As of January 23, 2019, this update is no longer offered on Windows Update as an automatic update, but rather only to "seekers" who go to Settings > Update & Security > Windows Update, and then select Check for updates, as is expected.  This update continues to be available on WSUS and Microsoft Update Catalog."
