Retrieve Result from TestStand Step by Step Name
Updated Jan 28, 2019
  • TestStand
I want to retrieve the result of a TestStand step by using its step name as opposed to its step ID or step index. How can I access this property in TestStand?
This result will be located in RunState.Sequence.Main["Your Step Name"].Result. This property can be used in any expression in which you need the result.
If you just need to retrieve the current step's name, you can just use the property Step.Name or the function NameOf(RunState.Step).
