My Linux system is not allowed to connect to the internet due to my company's privacy or security policy. Are there any methods to install Linux device drivers offline on my computer?
NI provides two scripts to clone or create custom repositories for use on offline systems. These scripts target either the RPM- or Debian-based Linux distributions that NI supports. This article instructs you on how to use the scripts to create offline repositories for installing software from the NI Linux Device Drivers repository on ni.com to an offline machine.
The offline installation media creation procedure requires a system running the same distribution as the target system with an internet connection to be able to access NI’s repositories. You must have root privileges on the system and must install a set of prerequisite software for the script to run properly.
The Python scripts mentioned in the instructions are available for download at the bottom of this article.
