Adding the UUT Serial Number to the Report File Name
Updated Oct 29, 2024
  • TestStand
I would like to add the UUT serial number in the report file name after executing the main sequence. How can this be done in TestStand?
One way of how this can be achieved is by following the next steps:
  1. In the Configure tab click on Result Processing and select Options from the Report field.
  2. Untick Store UUT Report in Batch Report File.
  3. Go to Report File Path Name window.
  4. In the Generate Report File Path section, choose any File/Directory Options apart from Specify Report File Path by Expression.
  5. Tick the selection box for New UUT Report File for Each UUT.
By selecting the New UUT Report File for Each UUT option, the serial number of the current UUT is added to the base name of the report file. This can also be done using the batch model.
