How to Wire Limits to AKD EtherCAT Drives
Updated Mar 15, 2019
  • AKD Series Servo Drive
I have an AKD EtherCAT drive and I need to know how to wire up the limit switches for my motion system.
Use the AKD X7 and X8 connectors to connect additional I/O such as limit switches, position capture (registration) inputs, or other I/O as required by your application. Refer to the AKD Installation Manual for information about connecting digital input and output devices to the AKD EtherCAT servo drive.
AKD to NI SoftMotion Signal Mapping
AKD Connector Terminal
NI SoftMotion Pin
Signal Mapping
DI1 (X7 pin 10)
DI0
Home
DI2 (X7 pin 9)
DI1
Capture (Registration)
DI3 (X7 pin 4)
DI2
Forward Limit
DI4 (X7 pin 3)
DI3
Reverse Limit
The image below shows that the associated pins can also be seen in the Axis Configuration windows in LabVIEW SoftMotion Module.
SoftMotion digital inputs and outputs are 0-based, while the digital inputs and outputs on the AKD EtherCAT servo drive are 1-based. This means that Digital Input 1 on the AKD corresponds to DI0 in the SoftMotion software.
