Create>>Graph Indicator Option Does Not Appear When I Right Click the Terminal
Updated Jan 18, 2019
On the output terminal of an Express VI, VI, or function on the block diagram, when I right-click >> Create, I do not see the option Graph Indicator. How can I make this option appear?
The Graph Indicator option only appears if you right-click a dynamic data type output terminal of an Express VI, VI, or function on the block diagram. To make this option appear, right-click a dynamic data type output terminal.
You can use the Convert to Dynamic Data Express VI to convert numeric, Boolean, waveform and array data types to the dynamic data type.
