How to Convert String Containing Hexadecimal Number to Hexadecimal String
Updated Jan 31, 2019
If I type a hexadecimal string into a normal text box, how can I convert it into the correct hexadecimal number, and not the hexadecimal version of the underlying ASCII?
This can be achieved by processing the normal string two characters at a time, two ways to achieve this are shown in this code.
In the upper branch, the string length is obtained and a logical shift used to divide it by two. The loop the converts the incoming string, two characters at a time, into hexadecimal format (%2x). This is then typecast back into a string before being displayed.
In the lower branch, the incoming string is typecast from a string into an array of U16 numbers. This is then converted array by array into hexadecimal in the loop, before being displayed on the output.
