Changes in Ribbon Cable Connections from NI-2532 to NI-2532B
Updated Oct 9, 2025
  • TB-2640
  • TB-2640B
  • PXIe-2532
  • PXIe-2532B
  • PXI-2532
  • PXI-2532B
I have upgraded from PXIe-2532 and TB-2640 to PXIe-2532B and TB-2640B, but TB-2640B has different connection labels than TB-2640. How do I change my ribbon cable connections for use with the new terminal blocks?
NI PXI/PXIe-2532B (NI 2532B) is designed as a replacement for PXI/PXIe-2532 (NI 2532). The cables currently used in an existing NI 2532 system with the TB-264x can be swapped directly to plug into a system with the NI 2532B and a TB-264xB.
Refer to the following images to see how current configurations cable connections can be directly swapped from the NI TB-2640 to the NI TB-2640B.
NI TB-2640 Terminal Block Signal Connections
NI TB-2640B Terminal Block Signal Connections
The following tables show the corresponding connection between TB-2640 and TB-2640B.
Terminal Block ModuleColumn Connection Header 1Column Connection Header 2Column Connection Header 3Column Connection Header 4
NI TB-2640UCCB-J3LCCB-J3UCCB-J2UCCB-J3
NI TB-2640BJ2J3J12J13
Terminal Block ModuleRow Connection Header 1Row Connection Header 2
NI TB-2640J3J4
NI TB-2640BJ4J5
