Cannot Read 5 V From the Supply Pins of the NI 9411
Updated Jan 18, 2019
  • NI-9411
I see that according to the pinout of the 9411 the pins 4 and 5 of this module can output a signal of 5 V. However, when I measure the output of these pins I always measure zero volts. Why is this happening?
You need to connect a power supply to the screw-terminal connectors that are shown in the image below.
As is specified in the datasheet, this power supply must be between 5 and 30 VDC
