Error When Building a MathWorks, Inc. MATLAB® Plant Model in Veristand
Updated Feb 20, 2019
  • VeriStand
When I try to build a MathWorks, Inc. MATLAB® Plant Model in Veristand, the build fails at the "Generating TLC Interface API" step and I get the following errors:
  • The specified index (11) was out of the range 0 - 10
  • The argument for an [] operation must be a repeated scope symbol, a vector, or a matrix
  • Error using tlc_new
  • Error in tlc
  • Error in build_target
There are several ways to resolve this error:
  1. Verifying that the model does not contain any "%" characters.
  2. Inline parameters in your MATLAB model. This can be done by selecting Inline Parameters in the Model Configuration Setup in MATLAB®.
  3. Enable TLC Debugging in MATLAB®. This can be done by going to Configuration Parameters > Real-Time Workshop > Debug and selecting Start TLC debugger when generating code. After selecting Build Model, a debugger window will appear. Type Break Error in this window, then Continue. MATLAB® will highlight the first error encountered, if any.
MATLAB®, Simulink®, and Real-Time Workshop® are registered trademarks of The MathWorks, Inc. All other trademarks are the property of their respective owners.
