Where Can I Find S8-Serial-Cable-Pinout Datasheet or Pin Mapping Document
Updated Jan 28, 2019
  • Serial Cable
I have a S8 Serial Cable that I want to use with RS 232 or RS 485 signals and I am looking for the datasheet or the pin mapping document of the cable but I cannot find it.
Since the S8 Serial Cable has a RJ50 connector and a DB9 connector, you can find the corresponding pin mapping in the document Converting an RJ50 Serial Connector to DB9 or DB25.
This document also has the corresponding signals for both the RS 232 and RS 485 serial ports.
