I am using LabVIEW for Image Processing and when I open the IMAQdx VIs and examples, I get the following error:
The library specified for this node cannot be found or cannot be loaded. Right-click the Call Library Function node and select Configure, then choose the correct library name or path.
OR
IMAQdx Error
Error 0xBFF69024
DLL Could not be found
