NI 9802 Compatibility with Linux Real-Time Based CompactRIOs
Updated Jan 28, 2019
  • NI-9802
  • NI-9802 SD Memory Card
  • cRIO-9039
  • LabVIEW Real-Time Module
  • NI CompactRIO
I have a NI 9802 SD Card module and I want to use it with a cRIO-9039. When I discover my C Series modules, LabVIEW doesn't recognize the module, and it is also not available in the list of C Series modules when added manually.
The NI 9802 is officially not supported by the cRIO-903x and 906x models. You can visit the Software Support page for CompactRIO to make sure which C Series module is compatible with the software modules and CompactRIO Controller you are using.
Some of the latest CompactRIO Controllers have a built-in SD Card slot that can be used to access your memory card from the Real Time application, instead of using the NI 9802 module.
