Changing the Channel Configuration of an R-series Board By Channel
Updated Jan 18, 2019
  • PXIe-7857
  • LabVIEW FPGA Module
I have an R Series PXIe card, 7857R, and would like the change the reference configuration on the card by channel.  For instance I would like some of the channels to be differential and some of them single ended inputs.  Is this possible?
For many R Series cards, including the 7857R, the reference configuration can be changed in software, however all channels must be set to the same configuration and and each channel cannot be set independently to different values.
