NI-9881 CANopen Module Not Available for Firmware Update
Updated Jul 17, 2026
  • NI-9881
  • NI-Industrial Communications for CANopen
I have an NI-9881 CANopen module installed in a CompactRIO system and the module reports that a firmware update is required.
I may experience one or more of the following symptoms:
  • The module does not appear correctly in NI MAX.
  • The module does not appear in my LabVIEW™ project.
  • Another CANopen module is detected while the NI-9881 is not.
  • I receive an error indicating that the correct firmware is not installed.
  • I cannot access firmware upgrade options for the module.
The NI-9881 CANopen module requires a specific FPGA configuration and CANopen software installation before it can be detected and updated.
  1. Verify that the required software is installed:
    1. For the host computer:
      • LabVIEW Real-Time
      • LabVIEW FPGA
      • NI CompactRIO Device Drivers
    2. For the CompactRIO controller:
  2. Configure the CompactRIO system correctly.
    1. For cRIO-903x, cRIO-904x, cRIO-905x, and cRIO-906x systems, proceed to the firmware update procedure (step 3).
    2. For other CompactRIO controllers, open labview\examples\NI-Industrial Communications for CANopen\Utility\Module Firmware Tool\subVIs\CANopen cRIO FPGA Compile Instructions.vi and follow the instructions displayed on the front panel.
  3. Update the NI-9881 firmware.
    1. For cRIO-904x and cRIO-905x systems, follow the procedure described in this related article.
    2. Open CANopen Module Firmware Update.lvproj from labview\examples\NI-Industrial Communications for CANopen\Utility\Module Firmware Tool.
      • In recent versions of the NI-Industrial Communications for CANopen driver software, the path may differ. Specifically, it can be found under C:\Program Files\NI\LVAddons\nicanopen32\1\examples\NI-Industrial Communications for CANopen\Utility\Module Firmware Tool
    3. Add the CompactRIO controller to the project.
    4. Add the NI-9881 as a C Series Module under the chassis resources.
    5. Select the appropriate slot location.
    6. Deploy the chassis configuration.
    7. Add Module Firmware Update.vi (located in the labview\examples\NI-Industrial Communications for CANopen\Utility\Module Firmware Tool directory) under the Real-Time controller.
    8. Run the VI and follow the front-panel instructions to complete the firmware update.
  4. Verify that the installed CANopen driver version matches the firmware version being installed. For example, NI-Industrial Communications for CANopen 2025 should be used when installing 2025 firmware.
  5. Verify the controller mode requirements. Depending on the CompactRIO controller model, the update process may require either Scan Engine Mode or FPGA Interface Mode.
The NI-9881 firmware cannot be updated directly through NI MAX because NI MAX does not communicate directly with the module. Firmware updates must be performed through the CANopen firmware update utility and LabVIEW project environment.
The NI-9881 CANopen module depends on the NI-Industrial Communications for CANopen software stack for module discovery and firmware management. A mismatch between driver version and firmware version can prevent the module from being recognized correctly or can generate firmware compatibility errors.
