Modular Data Acquisition
High-Performance Test
When accessing the LabWindows™/CVI™ Download page, there are several options that can be changed in order to download the version of software you need for your project. The initial setup for our LabWindows™/CVI™ download can be seen in the image below. Take note of the option for Application Bitness and Included Editions. If you change the Application Bitness to the option "32-bit & 64-bit", you will be able to see that the Included Editions change to "Runtime". This can be seen in the image below.After changing these settings, you should be able to download the Runtime version of the software. As a note, you can also download and install the LabWindows™/CVI™ 2019 Runtime version via NI Package Manager. You can check the Related Links section for more information on how to install software using NI Package Manager.
Installing, Updating, Repairing, and Removing NI Software
