Create Application/Library from Item Option Missing When Right-Clicking VI in NXG
Updated Jan 9, 2019
  • LabVIEW NXG
  • LabVIEW NXG Application Builder
I am trying to build an application from a VI in LabVIEW NXG, but when I right-click the VI in the menu, there is no Create Application/Library from item option.
  • When a .gvi file is already part of an application, you will not see the option to Create Application/Library from item.
  • Move the .gvi file out of the existing application (the .gcomp file) and back under the main project tree. The option to Create Application/Library from item¬†should return.
