I built a LabWindows™/CVI™ executable, but when I try to deploy it on another computer I get the following error:
"Developer Error. The following Errors were found in your ini file: 1. Missing Section: [O] 2. Missing Key: [O] Path Correct the ini file and try again". The details section reads:
\ConfigInfo.cpp(3422): InstallerError 11006
Developer Error. The following errors were found in your ini file:
Correct the ini file and try again. "
