I am attempting to compile an FPGA VI. This same VI has been compiled successfully several times, and I'm in the process of recompiling after several small changes. However, this time the process fails and FPGA compilation window shows the following error message:
LabVIEW: An error occurred while saving the document.
Error -2625 occurred at Failed to write file Invoke Node in niFpgaCompileWorker_ConvertBitstreamToBitfile.vi->niFpgaCompileWorker_CreateBitfile.vi->niFpgaCompileWorker_JobComplete.vi->niFpgaCompile_Worker.vi:6460001
Possible reason(s):
What is the cause of this issue and how can I resolve it?
