Modular Data Acquisition
High-Performance Test
I want to have two versions of the Vision Acquisition Software (VAS) installed at the same time on one computer. Is this possible?
You can only have one version of VAS installed at a time. If you require to developing on multiple versions of LabVIEW, you can check the LabVIEW and VAS compatibility and find a check if there is a version of VAS which supports both LabVIEW versions.
