You can configure the timing properties of the nidaqmx.task class as shown in the
reference document. One way to do it is using the cfg_samp_clk_timing method. To do this, follow these steps while writing your script:
- Import the required timing constants using the following lines. More information can be found on the Constants section on the reference.
from nidaqmx.constants import Edge
from nidaqmx.constants import AcquisitionType
- Create your task and add channels to it. (This example will use a digital input task)
with nidaqmx.Task() as digitalInputTask:
digitalInputTask.di_channels.add_di_chan("cDAQ1Mod3/port0/line0", line_grouping=LineGrouping.CHAN_PER_LINE)
- Use cfg_samp_clk_timing to configure the timing options
digitalInputTask.timing.cfg_samp_clk_timing(1000, source="", active_edge=Edge.RISING, sample_mode=AcquisitionType.FINITE, samps_per_chan=5)
The parameters for this method are the following:
- rate (float) – Specifies the sampling rate in samples per channel per second.
- source (Optional[str]) – Specifies the source terminal of the Sample Clock. Leave this input unspecified to use the default onboard clock of the device.
- active_edge – Specifies on which edges of Sample Clock pulses to acquire or generate samples.
- sample_mode – Specifies if the task acquires or generates samples continuously or if it acquires or generates a finite number of samples.
- samps_per_chan (Optional[long]) – Specifies the number of samples to acquire or generate for each channel when using FINITE_SAMPLES .
Your code should be similar to this:
import nidaqmx
from nidaqmx.constants import LineGrouping
digitalInputTask.timing.cfg_samp_clk_timing(100, source="", active_edge=Edge.RISING, sample_mode=AcquisitionType.FINITE, samps_per_chan=50)
data = digitalInputTask.read(50);
print(data)
