Deploy Result Processing Options Using TestStand Deployment Utility
Updated Jan 2, 2019
  • TestStand
I have developed a test sequence using TestStand with custom report options but after deploying my test sequence, I can't retrieve the same reporting options on my deployment system.
The TestStand result processing and model plugin options are stored in the TestStand Configuration directory. So you also need to include the required files from the TestStand Configuration directory in your deployment image using the TestStand Deployment Utility.
The required configuration files to retrieve the same result processing options in the deployment system are found in the ModelPlugins directory as shown below with the TestStand Deployment Utility:
In case you need to deploy more TestStand configuration settings, choose the required .cfg or .ini file to add to your deployment image as shown in the following link regarding the global configuration settings:
Deploy Global Configuration Settings with TestStand Deployment Utility
