How Much is Delay Between Start Trigger and Digital Data Generation for PXIe-6556?
Updated Jan 25, 2019
  • PXIe-6556
If I am using an external trigger at PFI line of PXIe 6556, how much will be the delay between the time trigger arrived to device and actual digital data is generated?
The delay between start trigger and digital data generated would be 6 Sample clock cycles+600ns for PXIe 6556.
Same information is also available in specification sheet of PXIe 6556 .
