sbRIO SD Card Throughput
Updated Dec 24, 2018
  • sbRIO-9627
  • sbRIO-9637
  • What is the SD read/write throughput that I can reach with a Single Board RIO?
  • What SD card class is recommended to use with a sbRIO?
The sbRIOs housing a SD card slot are:
  • sbRIO 9627
  • sbRIO 9637
The sbRIO 9627 and sbRIO 9637 Specifications report a maximum throughput of 12 MB/s when performing reading operations and of 9 MB/s when writing. In order to exploit such speeds it is recommended you use a SD card featured by a SD Speed Class Rating of 6 or higher.
