Hardware Required for Using FieldBus Protocol on cRIO
Updated Dec 24, 2018
  • cRIO-9012
  • cRIO-9014
  • cRIO-9022
  • cRIO-9023
  • cRIO-9024
  • cRIO-9068
  • cRIO-9076
  • cRIO-9081
  • cRIO-9082
  • USB-8486
  • NI-FBUS
I need to communicate through FieldBus with third-party devices using a cRIO: what hardware device do I need?
You can use the USB-8486 for connecting your cRIO with your Fieldbus device and use the NI‑FBUS driver, NI‑FBUS Configurator, and NI‑FBUS Monitor for programming.
As reported on the NI-FBUS 16.0 Readme (latest NI-FBUS drivers version), however, just a subset of the RIOs are supported: you can use the USB-8486 only with the following cRIOs:
  • cRIO 901x
  • cRIO 902x
  • cRIO 9068
  • cRIO 9076
  • cRIO 908x
Additionally, as indicated on the readme, the NI-FBUS cRIO support has been dropped starting from NI-FBUS 15.0: you can therefore use the USB-8486 with a cRIO only with NI-FBUS 5.0 and 14.0.
