NI MAX Does Not Show Remote Systems Tab or Devices on My Network
Updated Jun 8, 2026
  • PXI Chassis
  • NI CompactRIO
  • I cannot see the Remote Systems tab in NI MAX.
  • I cannot see my device under the Remote Systems tab in NI MAX.
Devices will only appear under the Remote Systems tab in NI Measurement & Automation Explorer (MAX) if they are running Real-Time Operating Systems (OSes).
Devices running Windows OS will not be seen under Remote Systems of a separate PC on the same network. Instead, they should be accessed through the Windows Remote Desktop Connection application.
Not seeing Real-Time devices under the Remote Systems tab or the tab itself is explicitly caused by NI MAX. The issue can be solved by following one or more of these steps:
