Change the Text in the Title Bar of Panel in LabWindows™/CVI™
Updated Jan 10, 2019
  • LabWindows/CVI
I want to modify the text in the title bar of the user interface panel using a function call in LabWindows/CVI. How can I do this?
Use the SetPanelAttribute function with your specific panel handle and adjust the ATTR_TITLE attribute to adjust the text title of the panel. Example code shown below.
SetPanelAttribute(panelHandle, ATTR_TITLE, "Your Title Here");
This attribute cannot be adjusted using the SetCtrlVal function since it is not a control. Other panel attributes can be found in the List of Panel Attributes in the LabWindows/CVI Help.
