I Want To Change The Property Of A Control Without Running The VI
Updated Jan 7, 2019
I want to dynamically change the properties of a control depending of the value of a button for example.
Is it possible to do that without running my VI?
It is not possible to dynamically change the properties of controls without running the VI.
The reason is that to modify the property of a control, you must use a property node:
But, this property node will be executed only if you run the VI.
If you want to learn more about the property node, please see here .
