How to Read a Clock Using a Digital Input?
Updated Jan 17, 2019
I'm trying to read a clock signal using a Digital Input Task with NI-DAQmx. What is the sample rate needed to acquire the signal in the best way possible?
Based on the Nyquist–Shannon sampling theorem, the minimum sample rate needed to acquire a signal is 2 times the frequency of the signal of interest.
For example, if you want to acquire a 1 MHz Clock Signal, you need at least a sample rate of 2 MS/s.
If you use a sampling rate smaller than the frequency of the signal, there is a chance the signal will still look like a clock signal. However, the frequency of that signal might be incorrect due to an overlap of the values in the samples acquired.
