Unexpected Report Rows Number
Updated Dec 17, 2018
I am using LabVIEW Report Generation Toolkit Append Table to Report.vi, but I see that the report being generated has fewer rows than those I expect. What can be the cause?
  • Check that the text data input parameter of Append Table to Report.vi is a 2D Array with the expected row number
  •  Append Table to Report.vi expects the report in input parameter specifying the report appearence, which is created with the Create Report.vi. Such VI can create a report from a template file by wiring its template input parameter. If this is the case, verify that the template file used for creating the report does not have a limit for the row number of the report
