What is the Voltage Level of the Counters on the cDAQ Chassis
Updated Dec 16, 2018
  • CompactDAQ Chassis
What is the voltage level of the counters on the cDAQ chassis , how do I know what is high and low voltage (1 logic or 0 logic)?
The high/ low logic is determined by the digital Input of the card that connected to chassis.
For example, if you have a NI 9401, verify the voltage levels on the NI 9401 specifications.
