Create a Pointer to Use the MoveBlock DLL
Updated Jan 28, 2019
I use the MoveBlock DLL in LabVIEW to read data in a memory address:
This function needs a pointer as an argument, how can I create a pointer in LabVIEW?
You can use the DSNewPtr DLL. You transmit the size of the pointer in bytes and the result is the pointer created.
You can use this snippet or the VI attached for the allocation and the release of the pointer:
Please drag and drop this snippet in LabVIEW to use it.
