- Use the Print direct button on top of the toolbar.
- Direct yourself to the File tap on top of the window and select Print or the other print option available on the dropdown menu.
If you select
Print direct button, you will not have access to some previous printing configuration. If you wish to change the printer or change some settings before printing, use Ctrl+P or go to the
File tab and select
Print options.
