How Can I Print My Circuit on Multisim?
Updated Jul 14, 2022
  • Multisim
How can I print my circuit from Multisim?
  1. Use the Print direct button on top of the toolbar.
  2. Direct yourself to the File tab on top of the window and select Print or the other print option available on the dropdown menu.
If you select Print direct button, you will not have access to some previous printing configuration. If you wish to change the printer or change some settings before printing, use Ctrl+P or go to the File tab and select Print options.
