Keep Project Hierarchy When Building Source Distribution
Updated Apr 10, 2019
I tried to build my project into a Source Distribution file and it just put all of the files in one directory and it was not meaningful.  Is there a way to keep the folders in the project?
For the Source Distribution, if you want to keep the same hierarchy, there is a check box when building your distribution that will allow you to do this.  This box can be found in the Application Builder >> Destinations >> Destination Type.  You can choose to make the distribution a directory and then click the box underneath that, allowing the distribution to "Preserve disk hierarchy".
