Error -1074384345 When Deploying System Definition File
Updated Dec 18, 2018
  • VeriStand
  • NI-XNET
I'm trying to deploy my VeriStand system definition file and I get
Error -1074384345 occured at
Possible reason(s):
NI-XNET: (Hex 0xBFF63227) Remote communication with the LabVIEW RT target failed because the host and target versions of NI-XNET are different. Solution: On the target, install the same NI-XNET version that is installed on the host.
You need to install the same version of NI-XNET on Windows and on cRIO, but sometimes the error might come up also if the version are the same. In this case try always to reinstall the NI-XNET driver on the target and on Windows.
