Blacked Out DAQmx Timing Property Nodes
Updated Feb 8, 2019
Programming Language
  • LabVIEW G
I cannot run my application and Block Diagram Error is referring to blacked out Timing Property Node. I have all the necessary software installed, what may cause this issue?
First of all, please check what is the version of your NI-DAQmx Drivers and it's compatibility with your LabVIEW and Operating System version. Get familiar also with this KB: Limited DAQmx Functionality After Installing NI-DAQmx Drivers and ensure yourself that NI-DAQmx: ADE Support, Device Drivers and MAX Configuration refers to the same version. If not, please reinstall your NI-DAQmx Drivers.
