Wiring NI Power Supply with Respect to Ground
Updated May 29, 2019
  • PXI Programmable Power Supply
I'm using my PXI Programmable Power Supply to supply power with respect to ground. I do not wish to superpose the output onto another level. How should I wire the chassis ground on my module?
In this case, if using Channel 0 you'd connect a jumper cable directly between Channel 0 Output - (Terminal 2) and Chassis Ground (Terminal 4) to ensure your Channel 0 Output stays grounded with respect to the PXI(e) Chassis.
