Two CompactRIO Chassis Have the Same Serial Number on NI MAX Report
Updated Jan 9, 2019
Two NI-MAX reports were made for two separate chassis to look at their differences, this was done on two completely separate systems at different times.The NI-MAX report seemed to show that the serial numbers for the two chassis were the same.
This indicates NI-MAX is corrupt and needs to be reset, to do this you'll need to follow the steps in the following article: How to Fix or Reset the NI MAX Database File.
Once MAX has been reset the correct serial numbers for the two devices should be shown on each report.
