How Do I Reverse my Channel Values in DIAdem?
Updated Dec 7, 2018
  • DIAdem
I have a channel of values sorted in a certain order and I would like to reverse the values of this channel so I can have the last values at the beginning and the first values at the end.
Is there a function in DIAdem that would allow me to reverse the values of my channel?
There is a function in the Channel Function group of the DIAdem Analysis panel bar that can be used to sort the values of a channel in DIAdem. It is the Sort Channel Values function that you can access by clicking Analysis -> Function Group -> Sort Channel Values as shown below.
Once you have selected the Sort Channel Values function, you can use the dialog box to sort values in a data channel in ascending or descending order and to relocate the values in channels with the same index as shown below.
For more information about the Sort Channel Values function, please click here.
