Archived:How do I Dynamically Load LabVIEW Built Shared Libraries from C on Linux?
Updated Dec 11, 2018
National Instruments does not actively maintain this document.
  • Linux
Programming Language
  • C
If I build a shared library (.so file) on Linux and then try to load it dynamically from C instead of linking the shared library directly with the C program and the RT Engine, the program hangs when it attempts to initialize the RT Engine. The following example code demonstrates loading a shared library dynamically from C:
void *libHandle = dlopen("MyLabVIEWDLL.so", RTLD_NOW);
To correct this error and dynamically load LabVIEW built shared libraries on Linux, add one of the following declarations to the program:
extern "C" void InitializeLVRTClient(); // C++ program
extern void InitializeLVRTClient(); // C program
Call this function without any arguments before using dlopen to load any LabVIEW built shared library.
This issue has been resolved as of LabVIEW 7.1.1 and above.
