Error -2147220694 When Opening NI RFSG Soft Front Panel
Updated Nov 29, 2018
  • NI-RFSG
Other
I'm trying to use RFSG Soft Front Panel but I'm getting error -2147220694 once I launch the application: Error -2147220694 occurred at niModInst Open Installed Devices Session.vi
What can I do to solve this problem?
This issue is related to NI MAX (Measurement & Automation Explorer), to solve this problem try to complete a reset from NI MAX database following the steps indicated on How to Fix or Reset the NI MAX Database File. Resetting the MAX database will just delete all the scales, tasks and configurations of recognized devices on the Measurement and Automation Explorer itself, it will not impact the hardware in any way.
You can create a backup of NI MAX database before resetting it referring to Export/Import (Save) the System Configuration in Measurement & Automation Explorer (MAX).
