How Do I Access the Compile Server Selection?
Updated Dec 18, 2018
  • LabVIEW FPGA Module
I want to compile the vi in FPGA with FPGA Compile Cloud Service. However, when vi is executed, 'Select Compile Server' screen window like below does not appear. How can I choose a compilation server in this case?
This problem occurs because you didn't check the checkbox of 'Prompt to select a compile server for each compilation'.
Navigate to LabVIEW: Tool»Option»FPGA Module session. At this session, you can see and select Compile server, Notification of Completed Compilation and Simulation. And you should select the checkbox of 'Prompt to select a compile server for each compilation' if you want the 'Select Compile Server' dialog to appear as below Figure.
