An Error Occurred While Installing a Package in NI Package Manager
Updated May 1, 2026
  • Package Manager
While installing software through NI Package Manager (NIPM), I get one of the following error messages:
An error occurred while installing a package: <package-name>.
An error occurred while removing a package: <package-name>.
An error occurred while installing the MSI at: <package-name>
The MAX Database exited abnormally
LabView Install Error 2022-06-20 15_56_17-Inbox - Danijel.Antic@tridonic.com - Outlook.png
This is a generic error returned by NI Package Manager when a package installation or removal fails. The underlying causes can vary widely, ranging from issues with a poorly constructed package (for example, when installing a custom product) to interference from antivirus software. Reviewing the logs helps narrow down the list of potential root causes:
  1. Look at NI Package Manager error logs to determine the underlying issue. It is recommended to start with errorlog.txt. Looking at the end of that log should show the most recent error that occurred.
    Note: You may need to enable Microsoft Installer (MSI) logs if the error occurred while running an MSI within a package that was installing. NI does not recommend leaving MSI logs enabled when not troubleshooting installation issues. Enabling MSI logs will increase the time it takes to install packages. If enabled for troubleshooting, you should disable them after troubleshooting is complete.
  1. If the error is not clear, contact NI Support or post to the NI Package Manager Discussion Forums.
If you are unable to generate logs, or if the logs do not contain relevant information, you can alternatively follow the steps below for initial troubleshooting.
  • Upgrade to the latest version of NI Package Manager.
  • Install all pending Windows updates.
  • Deactivate your firewall and antivirus software.
  • Restart NI Service Locator and NI Configuration Manager in Windows Services.
  • Check that there is enough free storage on your hard drive to install the software. Minimum storage can be found in the Readme file for the software.
  • Check that the %temp% directory has the correct permissions.
  • Install the packages you are attempting to install using its offline distribution, if available.
  • Try installing the latest version of this package available.
  • Install the packages you are attempting to install with administrator rights while logging in as an administrator on the PC (right-click on the installer and select Run as administrator).
  • Check if the system had any OS upgrades recently (Windows 10 to Windows 11 e.g.). These upgrades can have an impact on File Folder names or paths that are designated on the NI Package Manager for installations.
