Types Not Recognized Error When Loading LabVIEW DLL in TestStand
Updated Nov 26, 2018
  • TestStand
I get the following message when I load my LabVIEW DLL in TestStand and select a function:
This function does not have parameter information in the DLL or uses types not recognized by TestStand.
This error is expected because TestStand uses information from the type library of a DLL to display function prototypes and parameter information. If the type library is not present, the information cannot be displayed by TestStand.
To resolve this error, create a custom data type and add the paramenters of the DLL function manually.
Test the example located at <TestStand Public>\Examples\Fundamentals\Passing Clusters to Code Modules\Passing Clusters to Code Modules.seq and follow the instructions in Passing Clusters to Code Modules - LabVIEW .
