I am not able to deploy my VeriStand Project with PXI XNET Modules, the following error occurs:Deployment ErrorProject Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi<append>=========================NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi<append>=========================NI VeriStand: Error occurred at the following location:"Targets/Controller/Hardware/Chassis/NI-XNET"Error -307719 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.viPossible reason(s):NI VeriStand: Unable to discover XNET interface(s) before timeout elapsed. Contact National Instruments support at ni.com/support for more information about resolving this error. How do I fix this behavior?
The error shows up when VeriStand Engine fails to discover the XNET interfaces on your system.Follow the instructions below to troubleshoot the issue:
