Using IVI Step Types in TestStand 64-bit
Updated Nov 20, 2018
  • TestStand
Can IVI Step Types be used in TestStand 64-bit? If not, what are my alternatives other than using 32-bit TestStand?
IVI Step Types are not supported by TestStand 64-bit. This is because IVI Step Types for 32-bit TestStand were created using Microsoft Visual Basic 6.0, which is not supported by Microsoft in 64-bit processes.
The following are alternatives for customers who need to use IVI with 64-bit TestStand:
If 64-bit TestStand is required for memory purposes, consider identifying and resolving other memory growth issues in TestStand as a solution.
