以下のエラーは、CAN、DeviceNETまたはLINデバイスをリセットすることで解決できます。
Error -1074388986 occurred at ...
NI-CAN: (Hex 0xBFF62006) The object is already open in another application. Solutions: Ensure that only one application at a time uses an object , and that you close all objects prior to exiting your application (don't use LabVIEW toolbar's Abort button).
Error -1074388969 occurred at ...
NI-CAN: (Hex 0xBFF62017) This attribute's value must be provided prior to the Open. Solutions: Set the attribute using the Config function before the Open, and do not set the attribute at any later time; Do not configure multiple CAN Objects for the same ID.
