Can I Daisy Chain a TSN-Enabled Power Supply to a TSN-Enabled Chassis?
Updated Apr 5, 2019
  • cDAQ-9189
My cDAQ 9189 chassis has the ability to daisy chain multiple ethernet chassis together. Can I include a TSN-enabled power supply to the end of this chain?
Yes, a TSN-enabled power supply can be connected to the network through the 9189 chassis. The 9189 will act as an Ethernet switch in this instance. As long as the first Ethernet port of the 9189 is connected to the network, then the second port can be connected to the TSN-Enabled Power Supply.
